Having a weird issue where "Phone" is using %53 of my battery power. I tried a reset but it is still happening. Is this common? Has anyone else experienced this?
Restarting the phone won't change the battery used percentage amounts, you need to fully charge the phone for those to reset.
It's likely your phone app messed up and kept running in the background, restarting probably fixed it but you won't know until you are on another charge cycle.
