This doesn't make sense, I didn't use my phone until recently and boom my battery was drained. Any ideas?
Sent from my SM-G900V using Tapatalk
Live wall paper? Batteries have their good days and bad for sure....it does seem like every Android phone I have had has taken a few weeks to "adjust" or whatever. I unplugged mine yesterday at 7am and at 7pm it was 75% or so.....I've had it off charger today for 8 hours and it's at 65% but I am running a live wall paper today, have no idea if that's draining that much more. Probably is.
I agree....how long have you had the phone? Has it been like this the entire time? Also I notice there's a lot of icons on the left side of your phone showing...what apps are those?
When you don't use the phone like at night when sleeping, use TWO fingers to swipe down and then tap UPS. Battery performance will soar and almost no juice will be used while you are away from your phone.
So far I've gotten SIX days on the first cycle with 4:47 screen time and 21:44 battery time and then FOUR day with 3:20 screen time and 19:37 battery time.
Biggest drain on my phone is GPS, which I use both for tracking auto use and for tracking hiking. If some app using the GPS seemingly gets stuck running, the battery will last less than a day. If not using the GPS, it will last about 3 days in my use. When I see that happening (and confirm with a very steep discharge curve in GSam), I just reboot the phone and seems to take it back to normal. Long phone calls (using T-Mobile wi-fi calling) also drains the battery rapidly, probably more quickly than GPS but I use GPS more than wi-fi calling.
I generally charge the battery every second day, sooner sometimes. I'm waiting for Samsung to release the wireless charging back to make recharging easier.
You might want to check Google Location Reporting and see if it is off. Location reporting can use both GPS resources and data resources to keep updating your location in Google's records.
