A Androidn00bie75 Member Jun 27, 2014 18 0 0 Visit site Jul 6, 2014 #1 I decided to see how long it would take to run my battery down. .... Posted via Android Central App Attachments Screenshot_2014-07-06-13-55-40.jpg 57.1 KB · Views: 63
AZgl1500 Well-known member Feb 4, 2011 1,971 0 0 Visit site Jul 6, 2014 #2 That is good life for the use you gave it. Mine varies between two severe extremes. About 30ish hours to 4 or 5 days. Depends on how much I use it for data/wifi. I turn everything off when it is not being used. That way, just idle power is all that is used. Idling, the S5 will sip along at about 1% to 2% per hour.
P PainFX Well-known member May 2, 2014 852 0 0 Visit site Jul 6, 2014 #3 Check the time elapsed on the screen time. That's the only way to know if you got good battery life. 10% per hour of screen time would consider awesome.
bembol Trusted Member Jun 18, 2011 3,093 106 63 Visit site Jul 7, 2014 #4 Watched about 90% of Wimbledon today at work (LOL), wanted Federer to win. Amazing game nonetheless! I have 7% left it. Pro S5
K Karl Thomas Well-known member Jun 24, 2014 98 0 0 Visit site Jul 7, 2014 #5 Androidn00bie75 said: I decided to see how long it would take to run my battery down. .... Posted via Android Central App Click to expand... It seems your battery can last for a long time.Really great.Do you use a OEM one?
A Androidn00bie75 Member Jun 27, 2014 18 0 0 Visit site Jul 7, 2014 #6 Yes it's stock. I have only had the S5 For a week or so coming from a S2. Posted via Android Central App
