Okay, so I have seen similar questions posted about similar topics BUT I haven't seen anything hinting that these two things could be related. Which they may just be coincidental, I'm not sure...
I upgraded to a 64gb SD card, roughly two weeks ago, and I had several problems trying to transfer all of my music and pictures and whatnot over to it from my 32gb SD card...ended up losing a lot of them because of having to re-format the card (thankfully I have a memory card recovery program on my computer already, so losing things is not a concern at this point) HOWEVER, my phone fully recognized the 64gb card immediately, once I properly formatted it and whatnot, but only for like a day, then I started getting error notifications that the card was not properly inserted, or the phone was not reading it, etc...the card has been inserted into my phone for about 10 days at this point... a friend of mine also has the same phone as I do (s5) and it reads just fine, as does her card in my phone, so clearly it doesn't seem to be an issue with the card itself, or the card reader slot..since other cards are registering..?
Then there's also the issue of my battery randomly draining unusually fast the last few days...and this has only been happening over the last three days...I did go to Sprint two days ago and they "primed the battery" but it did not help at all (battery life went down from 87% to completely dead in less than 5 hours last evening)
So, as I said before, I'm not sure if, how, or why these two things could be related to one another, I'm thinking they may just be coincidental..has anyone else had a problem similar to EITHER of these? How can I fix the SD card issue? Sprint said they would replace the phone - I just don't want to run into the same problem with the new one if the issue is somehow caused by the SD card.
Thanks!
Thanks!
