I've typically been getting around 4.5-5.5 hours of screen on time with my S6 edge+, which seemed a bit low, however I couldn't find much online about what was normal for other users. I figured because the Note 5 has the same hardware and practically the same software, the battery life should be pretty comparable, right? Well apparently not.
I've found that users are getting around 6 to 7 hours of screen on time with the Note 5, a battery life I'd love to have.
So what is it? Is it a problem with my phone or does the Note 5 have an inexplicably better battery life?
Thanks.
Thanks.
