Why isn't my USB Port holding my usb cable stable enough?
A
AC Question
USB Port does't hold usb cable stable enough.
Hi guys, I bought my S6 Edge Gold yesterday, it is a amazing phone with a ****ty bat life but the main issue is that when I connect the micro usb to my s6 edge, it doesnt hold strong enough, it is really easy to make it disconnect. This happens with the original usb cable that was in the packaging.
Thanks in Advance
Misha
belodion
Co-Ambassador Team Lead
Moderator
Jun 10, 2014
39,389
255
83
Re: USB Port does't hold usb cable stable enough.
Hello Misha, welcome to Android Central.
I think you ought to return that under the terms of the warranty. Either the USB lead, or the USB port, could need replacing. Hopefully it will just be the lead, which would be easy to replace.
smokedog87
