Will the S6 Edge get the S6 Edge+ new Edge features. The ability to get to apps from the edge screen? Sorry if this was asked. Would be great to see the edge screen do something more than just put your favorite s there.
It was asked, but we won't know until samsung announces it, or doesn't. I can't see any technical limitations as the edge + is essentially just a larger screened edge, but perhaps samsung sees the apps edge as a differentiator, or that it only adds value when the screen is larger.
If you go under information stream in your edge options you can download more "edges" to use. I downloaded an app edge and have all my favorite apps on the edge now. It's cool, like a quick launch
