Wrong Sim card error on Verizon Galaxy S6 Edge Plus, how can I fix it?
A
AC Question
I bought a Galaxy S6 Edge Plus. The phone is originally for Verizon and I am trying to use it on Metro PCS. The phone makes phone calls and it works on the web, but there is an error that says "This is not a Verizon sim card" this error does not go away, I also cannot send SMS. I can receive but I can't send.
Any suggestions?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,602
4,751
113
Re: Wrong Sim card error on Verizon Galaxy S6 Edge Plus
Welcome to Android Central! Go to Settings>Mobile Networks>Access Point Names, and make sure you select MetroPCS (fast.metropcs.com). Also go to Settings>Mobile Networks>Network Operators and see if you can select MetroPCS there.
ramhja11
