A AC Question Dec 30, 2015 #1 is there a way to limit data usage on a samsung s6 edge my son has used 4 GB in a few days
dpham00 Moderator Team VP Moderator Apr 23, 2011 30,108 200 63 Visit site Dec 30, 2015 #2 Re: is there a way to limit data usage on a samsung s6 edge Verizon has a family base program which has usage controls. https://forums.androidcentral.com/e.../support/verizon-smart-family/&token=LVuXKabm If you are not on Verizon then check with your carrier, they might have a similar program.
K K_Quintana Member Jul 12, 2012 8 0 0 Visit site Jan 1, 2016 #3 Re: is there a way to limit data usage on a samsung s6 edge Go to settings, data usage, and set mobile data limit there.
dpham00 Moderator Team VP Moderator Apr 23, 2011 30,108 200 63 Visit site Jan 2, 2016 #4 Re: is there a way to limit data usage on a samsung s6 edge K_Quintana said: Go to settings, data usage, and set mobile data limit there. Click to expand... Yes but that can easily be bypassed by the son.
K K_Quintana Member Jul 12, 2012 8 0 0 Visit site Jan 5, 2016 #5 Re: is there a way to limit data usage on a samsung s6 edge If you have AT&T their app My AT&T has a way to turn off data. Go to Usage and then Turn off a member's data on or off. This way he can mess with it.
