Is it possible to disable App Icon Badge counter? [S7 edge]
Steemlives
91
Hello all,
Received my S7 Edge today and finally got it setup just the way I want except for one problem.... those damn badge app notification counters that appear on the app icons. They are driving my OCD crazy!
I know you could previously go in to the app manager and disable "BadgeProvider" but now when you go in to do so the "Disable" button is grayed out and it does not allow you to disable it.... anyone figure out a way around this yet?!
Thank you!
You can try to use package disabler from the play store. Not sure if it works on the s7, but it did for the s6/note 5
godef
