iPhone 6splus to Galaxy s7 edge
Gui0313
6
Hi guys,
I am contemplating a change from the IPhone 6 Plus to the Galaxy s7 edge. I think the phone is awesome after playing with it some at the store. Couple of questions that I have.
- How does iCloud email work on the s7 edge, I've had android before (S3 I believe) and the email push was terrible, emails wouldn't come in etc.
- I have iCloud photo sharing with numerous people in my family, is there anyway to continue sharing photos taken with the s7 edge? I know it's Android/IOS but is there some sort of workaround or app? Any solutions from the pros?
- I am also subscribed to Apple Music with family app, so I know Android has an Apple Music app now, anyone using it? How's it work?
FYI I also have an iPad Pro I use for school/work, mainly using MS Office apps.
Thanks! I hope to be picking one up today!
Hi guys,
I my opinion, since you are that integrated into the Apple Eco-system, I wouldn't switch to the Galaxy S7E.
You will lose all your seamless integration that you have taken for granted.
I have both devices, AT&T iPhone 6 Plus for work and Galaxy S7E as my personal device.
Each device has its pluses and minuses.
Again, in your case, I would not make the switch.
You won't get push email from iCloud but it still works. I use Apple Music and it's OK, but not as robust as on an iPhone.
You can use Dropbox to auto upload photos to a Mac and sync with the Photos app, but not as seamless as on iOS.
Overall I am happy with the switch from my iPhone 6splus to the S7E, but if you are that engrained in the iOS ecosystem it may be a difficult switch. I recommend you take advantage of the 14 day return policy to try it out.
Hixson21
