SwiftKey has become unusable
PsychDoc
1,402
7
38
I have happily used SK for years but about a month ago it started acting weird. Not inserting a space between words, double typing initial letters, etc. I wrote to the developer and they said they were "aware" of the issue(s) and were working on it. No ETA however.
Here's what I received:
******Ryan (SwiftKey)
Jul 1, 12:21 PM PDT
Hi,
I’m Ryan. Thank you for contacting SwiftKey Support! We are sorry to hear you're experiencing this issue with words doubling up.
Please be assured that we are aware of it, and are currently investigating as a matter of priority. We hope to get this resolved as soon as possible.
I will follow up here if we need any additional information to resolve this issue. Thanks for using SwiftKey and for your patience!*****
I'm just wondering if this is an isolated problem or if any of you have been experiencing the same issues. If you have, please contact the developer so the realize how bad a problem this really is.
I've also been having this problem. But it's so sporadic that I never really stress it. Just randomly I'll be typing a word and when I "space" and start typing again it just enters the same word again so instead of "almost there" I'll end up with "almostalmost" it's weird.
Posted from my S7 Edge via the Android Central App
Same thing is happening to me.
SwiftKey Beta just updated today and it lists a (potential) fix for this
I put up with this crap for awhile, waiting for an update to come. Every time I would type anything I had to go back and make corrections. Finally switched to google KB and it is working so well I will not be going back.
I switched to the Samsung keyboard because of the double issue. Was taking me longer trying to figure out how to fix it rather than sending the email itself
So far this glitch only happens on desktop sites for me. Any other app the keyboard works as it is supposed to.
Hey! Me too!
I thought maybe it was related to the Android N Beta which I am running on my Nexus 6P.
Having the same problem with double words . Switched to Google keyboard for. Waiting for a fix.
Yep. Went back to the stock Samsung keyboard. If your using any of the Material Dark themes, the stock keyboard is great.
I also had this issue. I am now using Samsung stock keyboard and it works
Yep i too noticed it which only happens when I am using the email app....
I have just learned to deal with it and i know it will be sorted at some point.
unhappy74
