I bought my Galaxy S7 Edge about a month ago and I've been loving it, however today I went to use a camera app from the play store (that I've been using fine for almost as long as I've had the phone) and it failed to open.
No error message.
I thought that was weird so I opened Snapchat.
Camera wouldn't load.
I then opened the default camera app and I got a simple "Camera failed" error.
I did some reading and couldn't find much, but read some suggestions to clear system settings or remove the SD card and reboot. Another suggestion was to wipe the system and dalvik caches from recovery. I would do this if I were capable, but I currently have TWRP recovery, which normally wouldn't be a problem, but TWRP currently can't get permission to write anything unless I wipe my phone, which I'm far from ready to do.
I've deleted the camera app from the play store. No dice.
I've cleared the camera cache and data from within settings. No dice.
I've cleared all system settings. No dice.
I've removed my SD card and rebooted. No dice.
So I essentially have two questions here:
Most pressing, how could I go about getting my camera to work?
If only through a cache wipe in recovery, how do I return to stock recovery so that I'm actually capable of doing anything in it?
EDIT- I just discovered that I'm unable to turn on the flash, as it's being "used by Camera". I feel like that could be important.
No error message.
