How to change keyboard back to simultaneous language after Samsung 7 Edge update?
Lrosalea23
3
My system advised that I had a new update. I installed it and it changed a bunch of stuff, mainly the look of things which is taking me a bit to get used to, but one of the things that annoys me is that it changed my keyboard/language settings. Before, I would have my keyboard on English US but type in two different languages (English and Spanish) and it would recognize both. It would autocorrect, etc. Now I have to toggle between languages. I can't figure out how to fix it. Anyone know?
Also, I don't like the color of my message bubble on my texts. Anyone know if there is a way to change this?
Cliffy0910
I agree Lrosalea23 this is the same problem I'm having. Very frustrating! Not sure how to correct....Sigh :-(
carolina sanchez
I'm having the same problem. I had English, Spanish and French. I would change the language on the spacebar, depending in which language I would type. After the update, it all went away. I added the languages again, but the keyboard is stuck on English. No autocorrect on the other languages and no keyboard to use special ortographic items. How can this bve fixed?
Madpiano
In the settings select virtual keyboard, then select sumsung keyboard, then go to language selection and choose and download your language))))
Diego Mejia1
This actually worked. Go to Settings>Language and Input>Virtual Keyboard>Samsung Keyboard> ADD YOUR 2ND LANGUAGE HERE...
It worked for me. Thank you Madpiano!!!
Lorelyne
it does not work for me. Of course I input french and english but it will not simultaneously recognise the langages to correct automatically. I have to slide the space bar to swap langages: which will also change the type of key board (qwerty or azerty). I cannot write with the azerty key board with English correction anymore... it is very frustrating... anybody has the answer please?
for galaxy S7
gomezju47
for galaxy S7
Prifg
4
I have the same issue, I even tried to complain with Samsung, but nobody seems to understand the problem, let alone to have a solution.
It's really annoying
redvulcan
You owe madpiano an apology, i did as he/her suggested and it cleared the issueand i can now swipe space bar and switch languages again
Prifg
4
But that's exactly the issue. Before the update we didn't need to swipe anything to switch languages. It would recognize the language automatically as you typed.
Maro87
I know exactly what you mean I used to be able to type polish and English and the keyboard would pick it up automatically and insert special characters if needed to
crazyjeeper99
Hi guys .. same trouble and no solution found .. I type in four languages and under android 6 it worked fine. prediction was switching automatically.. with android 7 now I need to switch manually the keyboard language which is very boring ...
CrystalLewis
