Annoying "Google TTS Voice Data" screen keeps popping up
dwade62
84
8
About a week ago I started to get the above popup. It displays all the languages available. If I select English (United States) there is no download icon so I know my phone already has it. Any other language shows the download icon. I exit out of it and within a few minutes the same popup appears. it does this periodically throughout my day.
Any idea why this is popping up and how do I stop it? My phone is an ATT GS 7 Edge on Nougat.
Thanks
Don
Re: Google TTS Voice Data
Is it possible that you're calling on it to "speak" some non-English text?
I've noticed when I open a texting app I sometimes get the pop up, but Ive had the app for a long time. I think I get the pop up when I try to use my phone at times too. It's not consistent when it does it, but it's extremely annoying.
Trying to use another language? I guess I can check the popup next time it shows itself and see if any other languages are downloaded.
I've searched online but haven't found any related posts. I don't know how to get it to stop.
Yes I am having the same problem and do not know how to fix it. Had hoped there might be an answer here.
I had really noticed it when/after I had installed a "Call Announcer". Thinking, I do that once in a while, that I need to remove the Call Announcer and see if the problem persists. Will get back on this...
-Chuck
Well, guess what?? I removed the call announcer and the problem went away. I haven't had that annoying problem all day since I removed the call announcer. I will monitor it for a couple of days without and with the call announcer. One of the requirements of almost all of these announcers is that Google TTS be installed.
Oh one more thing... I didn't have this problem with Marshmallow.
Well, another thing. It is NOT a problem with all Call Announcers. I have installed
"Call Announcer Pro" and it does NOT cause the problem.
shronlndry
