That's pretty cool said, for me, I use the most used apps, contacts and sports for my hockey teams.To me, it's like the task bar of a Windows PC.
I use it for the Device Maintenance panel for clearing the cache and shutting down background apps.
Thank you. I can't find smart select though for some reason.
Settings>Display>edge screen>edge panels. Check the box for smart select
And don't forget the animation part of smart select where you can make GIFs.Thanks, yes, that smart select for screenshots is awesome, much better than the pal to capture gesture in my opinion!
Absolutely, tons of awesome and useful features!And don't forget the animation part of smart select where you can make GIFs.
I've already made more than a handful of my own
Me too absolutely! I love having a clean interface. Only the calendar widget which is fully transparent is on my screen which I need.I use the edge for apps I would normally have on a different screen. I also use it for stocks and weather.
I find the edge screen really useful of course. It's nice for the quick most important apps, and for the screen shots.My mom has a Samsung Galaxy S6 Edge and has not yet programmed the edge screen for anything. I've told her about it but she doesn't really see a use for it.
If I had an Edge device, I'd use it for most-used contacts. But, as per usual, it all depends on specific user preferences.
Heck yeah absolutely.For sure! I really think I'd make use of that feature.
Haven't used weather edge. I use Weatherbug it has a temp display in my top notification bar which I loveHas anyone had trouble with the weather edge? It just says tap here to restore weather data but it just goes away and never shows anything. It worked fine on my s7 edge. Also did they get rid of the edge feeds I think they were called? You could swipe the edge when the display was off and it would scroll news and sports scores
Just wondering what uses people have for their edge displays? I use mine for my most used apps/ core Google apps, and the people edge screen.
I have Edge stuff turned on, but nothing happens.
Under Settings > Display > Edge Screen I have both "Edge Panel" and "Edge Lighting" selected.
Edge Panel is there. Edge lighting does not happen. I have yet to see what that looks like.
Never mind! I found the settings where you have to turn on edge lighting for individual apps.
