jakeinator21
I have the same problem. Usually the phone would freeze after I initiated some action for an app. The screen would freeze on the app, and the hard buttons would be unresponsive. The notification bar would be active still, so i could pull it down, but once I let it go after pulling it down, it wouldn't go back up. I could push the power button and the screen would go black, but when I pushed it again, it would display exactly the same screen. I was on Wicked rom at the time, thought it might be a rom issue, but it wasn't that bad so I just let it continue. After a week or so it started to get really bad. One day it stared freezing almost every hour, so I decided to flash back to stock. After going back to stock and doing a full wipe, including a format of the sd card, it seemed to do fine, but trying to install a zip via cwm recovery, it froze again. Unexpected to see it happening in recovery, as I assumed it was a software issue. Phone was fine for two days without freezing while it was running. On the third day, today, it froze again in the exact same way. So that's where I'm at now. Thinking I'll get it replaced.
