Hello, I posted this at the xda forum and I thought that I'll re-post it here for those that don't go to xda:
I don't know if anybody know about this fix or not, but I've just found a way to fix the lag when the home screen auto-orient from landscape to portrait and vice versa: click on the + button that you use to add widgets and apps to the home screen, select any tab other than the add widget tab, go back to your home screen and that's it no more lag! I believe the left and right screen transitions are smoother as well.
I do not know if this problem/fix is specific to our tab or honeycomb as a whole, but I'm glad I found a workaround since it was really bothering me. I hope this can be useful to somebody.
