gear 2 neo music player
kazrim
I've transferred a few mp3 folders/files to the neo but the player only lists and plays them as single tracks. Is there a way to access and play them as albums and not just shuffled album tracks played alphabetically.
Index77
108
Can you specify more what do you want. I might create alternative standalone music player
what about "folder audio player" suitable for audio books and albums with more features?
kazrim
I want to play a full album ie tracks 1-10 in the order intended and by the same artist.
At the moment I have put 5 different albums into the neo but the neo doesn't seem to have the option of playing each album separately. it just plays tracks ie. track 1 from album 1 and then track 1 from album 2 or just plays all the tracks from all of the albums alphabetically ie. track named alpha from album 3 and then track named ant from album 1 and then track named arise from album 5 etc
is there something I'm not doing correctly, missing, or should the folders etc be in a certain format or is this just the way the player on the neo does things.
Index77
108
actually you can play music by folder. click on the top-right button --> click on the top right button --> navigate to folders list and click on first item and then music will play in order
lizardchest
584
I picked up the gear 2 neo and the Galaxy S5 and can't seem to sync my music. Little help please
You are somewhat limited moving tracks over, by BT connection. I believe it's ten at a time:
Gear Manager>My Apps>Music Player settings icon. Selct your songs, wait a bit for transfer, should show up on your watch!
Also, by connecting to your pc via USB, I think you can drag and drop.
1812dave
3,133
35
yes, it is 10 at a time. kind of a drag when you want to send 100 or more songs to the watch as I have.
denverbob
I can't seem to view these tracks by folder. They just show up as one big list alphabetically. I tried your upper right corner twice tip and that just brings up playlists. An alternate player would be great.
clitrenta
517
I only put a small amount on mine but unfortunately, My Note 3 will only connect to either my Gear 2 or my LG BT Headset but not both at once. Rather annoying but whatever. Gear comes first.
Alison Woods
My gear 2 neo isn't showing up my computer.. when I plug it in it starts to charge but the computer isn't showing the gear anywhere... I wanted to transfer music onto my watch.
NoFaQ
203
I have the Jaybird Freedom BT earbuds, and I can connect them and the watch at the same time. From the phone, I can still switch the call between phone, earbuds, and watch.
Neverlift
Has anyone successfully transfered music to the gear 2 neo via the gear app music dial send songs to...etc?? Im using the Note 4 with Gear 2 Neo, Thanks! *Solved*
