Typical Battery Drain...?
Dankees
Trusted Member
Mar 26, 2011
687
What should typical battery life be?
How should the battery drain if left alone (connected via Bluetooth/Wi-Fi for an hour?
How should the battery drain if used for an hour straight?
I want to make sure that I am getting the correct readings, as I feel like my new watch's battery might be training more quickly than it should.
Thank you.
foxbat121
1,729
38
How do you know your battery drained that much if it is powered off? You have to power up the watch to check the status, right? Power off and power on process consumes a lot of power because the entire OS needs to be re-initialized from ROM into RAM.
