help customize lock screen: weather + alarm + clock
lorcar
7
Hi everyone
i haev z1 compact.
I'd like to customize a bit my lock screen, so to show current time, current weather (and maybe next few days as well), alarm in ONE page.
I tried few popular extensions, but it was not in ONE page.
I also downloaded Transparent Weather, but it has TWO problems:
1- I cannot resize it properly! i widen the widget as much as needed, but every time it shrinks back!
2- it doesnt show the alarm
any help?
thanks in advance
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,367
113
63
Dashclock can be added to your lock screen. Shows the clock mainly, and to the side are smaller but clickable tags, with the necessary add ons, like the weather, battery, and alarm.
The weather cannot display a forecast, but clicking on the weather, will take you to either the predetermined weather application, or, I have 1Weather, and that has a supported dashclock extension. One click and I am in my weather application.
lorcar
7
thanks
is there a reason I cant keep the lock screen widget the dimension i want? it gets shrinked back every time
also, why cant I put more than one widget in each lock screen pane?
jendrke
thanks
got the same problem on my z3c, just looks like a clock, with a small icons, of weather and gmail.
I installed more features, but like you i can't see them on lockscreen :(
ecstasy89
