Phone transmitting every 19 seconds is killing battery
funeralplanner
50
This started about a week ago. That is when I just started using a launcher instead of tw. I don't know of any way to find out what exactly is the culprit. I looked at system panel lite but I don't think it registers cell usage. Need help, thanks.
RUSH
4,120
285
The best way is to first remove whatever it is you think might be the culprit. See if that fix the problem - If not, then try some troubleshooting.
Good luck.
funeralplanner
50
Well I didn't download anything but the launcher, and now that is gone. I had some program updates, but that is it. I noticed the problem when I couldn't go all day on my battery, so I decided to watch to see if data was polling and it was every 19 seconds.
Rdjinc
Active member
Nov 27, 2010
41
Mine is droping to and it started the first of the week I installed handcent and. Adw launcher I was goin.g to remove the launcher but may try looking at facebook first how do I find out the transmit times? I have charged from 40 % twice today and now I'm at 22%
Sent from my SPH-D700 using Tapatalk
cloudsofmana
