Nope. I can already tell you don't use your phone heavily. 1. You have nearly 60% remaining after 13+ hours. 2. Android OS, Android device idle, and the Android System are 3 of your top 7 users of energy. Those typically happen when the device is idle for extended periods. That chart is basically saying of the 43% of power that has been used, these apps are what has used. So, 30% of that 43% is used by the screen. Normal. Your screen is the biggest consumer of energy, due to sheer size, and I am guessing your brightness is kind of high.
Theoretically, you are getting about 25-28 hours on an 80% charge. I would love to have that kind of battery time.
