GrooveRite
I'm fairly certain that this will only address issues where Media is the number one process on the phone. And from what I've heard it absolutely works. The issue I'm having (and its possible others are as well) is that Maps is actually my highest useage (when I look at the battery info through the settings menu). However, if I look at my battery using GSam Battery Monitor I see that my highest app usage is actually the Kernel. When I look at the sub-processes included in the Kernel I see about 20 or so "Kworker" with various letters and number after. I've been unable to uncover what the cause of this is. What I will say is that disabling the Samsung sync made it part of the way better, but not back to my expectation.
Maps was my problem as well! I looked at everything, diabled the cache and stopped the process and it didn't clear up the problem. This is why I'm telling people that if you have problems after JB, you may have to reset the phone other than reformatting the SD card! I did both, resetted and reformatted and my phone is working beautifully!
