Results 1 to 4 of 4
    BlackHawkA4's Avatar
    Drop the Bag
    Posts
    Global Posts
    2,419 Global Posts
    Default Every port: auto rotate problem
    Is it just me or does every ICS rom have an auto rotate issue. It'll work at first and then all of a sudden the screen will stop auto rotation on anything I try. Then I come back later and it'll work and then it'll stop working.
    Any fix or we just living with this for now?
    (I'm on CM9 right now came from Pete's).
  2. #2
    philbw's Avatar
    Posts
    Global Posts
    352 Global Posts
    ROM
    AOSP 4.1.1
    Default Re: Every port: auto rotate problem
    I only recall this happening a while back and I think it was on one of pete's earlier roms. The one I'm on now (pete's 2-2-12) doesn't have the problem at all.
  3. #3
    Skunkape60's Avatar
    Retired Ambassador
    Posts
    Default
    Nope.... not an issue for me.
    ____________________
    Just Flash It !!!
    http://forums.androidcentral.com/signaturepics/sigpic70132_2.gif
    Drop the Bag
    Posts
    Global Posts
    2,419 Global Posts
    Couldn't get it to stop on Pete's rom. After my last reboot on cm9 it appears it has worked itself out.
