I am not sure if this is limited to the Sprint Nexus S 4G or other droid devices are experiencing this. I downloaded the Easy Battery Saver app, which saved so much battery and I set it to "Intelligent Mode". This worked well for about 48 hours, but my data service would go in & out (The bars would be highlighted in white and not green...I was able to receive and make calls & texts, but every time I tried to go to a website, Facebook mobile app, twitter, etc...my phone acted as if I had no data connection).
I tried to change the app settings from Intelligent Mode to Normal mode and that did not fix the data going off & on. I then tried to uninstall the app and the data was completely off (signal bars never turned green). The only way I was able to turn on my data again is by reinstalling the app.
Any suggestions on how to either ensure data is on full time with the Easy Battery Saver or after I uninstall it?
I have already tried leaving my phone off for 10 minutes and turning it back on, and update my profile and PRL.
