Firmware issue after installing unleash the beast
zkornecki
3
I've used Unleash the Beast program to root and improve my Samsung Captivate and am happy with the results but I am unable to get the Kies program to work now so that I can install the 2.2 update. Kies keeps giveing me a cannot find firmware error. any Ideas or suggestions.
Thanks
Zb
That is what happens when you root. It messes stuff up. Try going back to JF6 and going that route, but if it doesn't install the Froyo update using Odin or install a custom Froyo Rom. That is probably your two best options for Froyo, rather than trying to do it through Kies. Or you may try Kies mini and see what that does.
godef
