SanDisk 64 gig ultra incompatible with Note?
ItsaRaid
613
10
On the forum, one of the ops posted that the above SanDisk SD Card is incompatible with the Galaxy Note2? Can anyone confirm this and does this apply to the 32 gig SanDisk Ultra as well?
Thank you in advance
Mobimop
110
8
Most likey needs to be formatted in the phone, I have a SanDisk Ultra64 microSDXC UHS-1 that I plan to pop into my new N2 later today, I'll update this post on my results.
Update: My SanDisk Ultra64 microSDXC UHS-1 works great in my Note 2....
inspectagadget1973
57
My SanDisk micro sd works just fine in my note 2. You do have to format in the phone tho.
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
Mobimop
110
8
Planoman,
Does the SD card (64 gig SanDisk) contribute any benefit to the GN2's performance.?
Not that the Note 2 needs it but a slow SD card could contribute to slow read and writes for photos, videos, etc. Best to get the fastest you can afford.
redmoss6
I installed a 32gb SanDisk Ultra in my Note 2 and it works just fine. I did format it before I did anything else because I read somewhere that that's a good practice, but other than that, I just popped it in.
planoman
3,605
94
Planoman,
Not really other than giving you a lot of storage. I take a lot of pictures and video and the HD video eats up the storage! I got the class 10 because I thought it would make a difference. I do see a difference when transferring things on my computer as the class 10 is faster. It is the best you can get right now but still not as fast as internal memory. That is probably why when taking pictures in burst mode, they go into the internal memory. I do like having the 64 GB card since you know it will be a while before filling it up.
ItsaRaid
613
10
Planoman,
Thank you!, did you reformat the SanDisk 64 Ultra in the GN2? If so does the Note 2 reformat it 8n Exfat32?
planoman
3,605
94
Planoman,
I did format it in the Galaxy S3 when new and then just popped it into my GN2. I believe it is formatted in exFAT. The only issue I had was trying to put one into the Galaxy Note 10.1 which needed to be FAT32. I returned the Note 10.1 and my understanding is that Samsung has since release a fix so it could accept a exFAT SD Card which is how the 64GB SDXC cards come.
ItsaRaid
613
10
Once again you come to the rescue. Why is Everyone making such a big deal about the SanDisk 64 Ultra? Isnt exFat32 the fastest of the 3 formats? Im planning to use it for my Music storage, ringtones and sounds. I was caught completely off guard with the cant move apps to SD card thing.
I ordered it from Amazon.com already, I guess had I known about all this hoopla I probably would have ordered the 32 gig instead. Gosh, couldnt beat the price though.
ItsaRaid
613
10
Will this work okay?
SanDisk Extreme 32gig. SDHC Class 10, UHS-1 Flash memory card 45 MB/s
SDSDX-032G-AFFP
from Amazon.com
iGalione
224
the card works great in the phone, had mine since release day wating, and it has always worked... the only problem or gripe i have, is the ability to move apps to SD, other than that, there are no other problems with it, it works wonderfully
nsurg
16
To the post a couple above about the "will this work" the answer is nope... that's an SD card. That will be rather tricky to put in the phone.
ItsaRaid
613
10
Of the 3 formats available, does exFat formatting offer a "Higher rate of transfer" than the other formats. Is there any advantage to exFat formatting. Lastly, is it possible the issue with moving apps to the SD card can be fixed without having to root the GN2?
This is based on the use of the microSD SanDisk 64 gig Ultra Card.
mtucker
125
9
Here are the read/write results I got with SDTools and my Sandisk class 10 64GB micro SD card on my Note 2. I formatted it in the phone.
ItsaRaid
613
10
I actually saw similar graphs posted by SanDisk. I would like to understand the advantage of exFat Formatting compared to the other formats available.
