Results 1 to 7 of 7
- 04-27-2012, 10:30 PM
Thread Author #1
Picked up the Note tonight, where can I find battery level??
Outside of the little green battery in the top right corner i cant seem to find anywhere that says what percentage of battery i have left. On my Droid 2 it shows the charge level (ie. 85%) and being I'm still using the older OS I still have the battery manager app which tells me. Is there something I'm missing?
Rev. - 04-27-2012, 11:43 PM #2
Re: Picked up the Note tonight, where can I find battery level??
I think if you're running stock, it only shows battery % if it's charging or you use a battery widget. The long way to see the % is to go into settings, then About Phone, then Status.
- 04-28-2012, 12:23 AM #3Palm IIIxe, Handspring Prism, Sony CLie, Tapwave Zodiac, Centro(AT&T), Palm Pre Plus(AT&T), Nook Color, HP Touchpad-32, HP Veer, Samsung Galaxy Note(AT&T), Nexus 7 (32), Nexus 4 (16)
- 04-28-2012, 07:45 AM #4
Rev, if don't want a widget on your homescreen you might want to check 'Go Power Master' in the Play Store. The app will give you battery level up in the notification bar so it's a little less intrusive and out of the way, but supplies you with some other other battery performance indicators when you pull down the notification bar.
- 04-28-2012, 08:40 AM #5
My personal favorite, is battery indicator pro. Does what I need it to do with some customization. They also have a free version. All in the Play Store.
- 04-28-2012, 08:58 AM
Thread Author #6
- 04-28-2012, 09:09 AM #7
Reply
