Just a warning, most people don't know about this, even Moderators post guides to uninstall bloat.
Deleting/Uninstalling bloat will prevent you from ever getting an OTA update on your phone again 99% of the time unless you have them all backed up and put them back where they were and reset the UNIX permissions correctly manually. In order to get the update, you will have to find an image of the ROM and reflash your phone, which will cause you to lose everything and your phone will be just like taking it out of the box the first time.
With that said, and with most people learning that the hard way (myself included) you should never delete/uninstall bloatware, but rather freeze it. Freezing makes your phone think it is uninstalled, it never runs, it doesn't show up, but you can defrost it at any time and it is back just like it was before.
Titanium Backup PRO and my own app, Bloat Freezer allow you to freeze apps.
