So, I just got my G2 a couple days ago. I did a quick google search and noticed some other people (on different networks) are having a similar problem. Let's see if the expertise here can figure this out.
When I turn on my WiFi I can't receive calls or texts. I find that generally speaking I can send texts (haven't tried calling out), but nothing will come in until after I turn off my WiFi.
Now, I'll say I have tried being called with my WiFi on, and then again off without otherwise touching or moving my phone, and it went through only while WiFi was off. Also, as soon as I turn my WiFi off and let it connect to the network decently again, it receives all my texts. The interesting thing is that it always tells me what time they were sent (instead of what time they got to my phone) which never happened on my last phone (a blackberry 9900) if I didn't get them right away.
What say you, Android Central community? My next plan is to see if I can disable the LTE (through the secret menu) and then see if that helps.
