Results 1 to 21 of 21
- 07-26-2011, 12:00 PM
Thread Author #1
GB OTA problems and issues tracker
With the update rolling out from T-Mobile I thought it would be appropriate to have an issue/problem tracking thread.
If you have the OTA from T-Mobile (not the leak from LG) post any problems you're having here.
Sent from my LG-P999 using Tapatalk
Issue #1: LG camera app missing in the Gingerbread update.
Solution: Dev's have ported it to Gingerbread. It still has some quirks, though, but they are working hard to get it perfect.
Issue #2: Some people are still seeing the authentication error when trying to update.
Possible Solution: Uninstall and reinstall the LG update software. May not fix the issue.
Issue #3: Refurbished units are not able to update.
No known solution.
Also, the LG "leak" and the T-Mobile release are the same, I just didn't want to create this thread until it came from T-Mobile.Last edited by Kevin O'Quinn; 08-01-2011 at 09:59 PM.
Forum Rules & Guidelines -- CLICK HERE
I'm an NVIDIA Tegra Champ. Here's what that means. It means that from time to time I might receive products and/or services from NVIDIA to evaluate them and provide feedback to NVIDIA and you, our valuable members. What this does NOT mean is that my opinion will be biased. Any opinion that I express here and elsewhere are solely based on my personal preference and any relevant expertise that I may/may not have on the subject matter. - 07-28-2011, 08:29 AM
Thread Author #2
Re: GB OTA problems and issues tracker
The LG camera app is missing in Gingerbread. I hope that LG is still working on it and will release it as soon as it's ready.
In the mean time it's been ported on XDA, but is a little quirky still. Would love to have this from LG directly.Forum Rules & Guidelines -- CLICK HERE
I'm an NVIDIA Tegra Champ. Here's what that means. It means that from time to time I might receive products and/or services from NVIDIA to evaluate them and provide feedback to NVIDIA and you, our valuable members. What this does NOT mean is that my opinion will be biased. Any opinion that I express here and elsewhere are solely based on my personal preference and any relevant expertise that I may/may not have on the subject matter. - 07-29-2011, 09:59 PM #3
- 07-29-2011, 10:02 PM #4
Wait......the LG leak is not the same as the OTA update? Then what is going to happen to those like myself who have a device that can't connect with the server due to an 'authentication error'? We will never be able to get official updates from TMO because of this issue?
- 07-30-2011, 06:29 AM #5
The LG leak and the T-Mobile OTA release are the same according to everything I've heard. You may or may not be able to get the update via LG or T-Mobile. Some can, and some can't. Not much rhyme or reason to it that I can see.
My son's phone gets an authentication failure for the OTA update, and his is stock, unrooted and not a refurb. Many had major issues with the LGUpdater software (it took me several retries and about 30 minutes for a complete download) and ended up with bricked phones.Lindel -- T-Mobile LG G2X
- 07-30-2011, 09:54 AM
Thread Author #6
OP updated. I've haven't heard of anyone getting a bricked phone because of the LG Updater software. Do you have a link?
I'm an NVIDIA Tegra Champ. Here's what that means. It means that from time to time I might receive products and/or services from NVIDIA to evaluate them and provide feedback to NVIDIA and you, our valuable members. What this does NOT mean is that my opinion will be biased. Any opinion that I express here and elsewhere are solely based on my personal preference and any relevant expertise that I may/may not have on the subject matter. - 07-30-2011, 08:40 PM #7
I tried to update my replacement (refurb?) unrooted G2x using the stock updater and no good (gives auth error). I tried using the pc lg mobile updater and it says i already have latest version. I haven't noticed any posts about this issue as if everyone who's tried to use the mobile updater works. Any ideas?
- 07-31-2011, 06:24 AM #8
- 07-31-2011, 06:26 AM #9Lindel -- T-Mobile LG G2X
- 08-01-2011, 08:51 PM #10
- 08-02-2011, 10:13 AM #11
Unistall the LG updater from your comp and the download that contains it. Re-DOWNLOAD and reinstall the program. That did the trick for two buddies of mine. Make sure though you unistall and delete the download. Then redownload the program and install. That should do the trick.
- 08-05-2011, 12:01 AM #12
- 08-05-2011, 12:50 AM #13
My G2X was bricked by the updated tool; it stalled mid-update and would only reboot to the same page. T-Mobile replaced it and the new phone is working great on Froyo so I"m hesitant to even try the OTA update at this point. Not that I have a choice since I keep getting "Connection failed" every time I try checking for software update on the phone.
- 08-11-2011, 04:40 AM #14
I've started getting the connection failed as well...it was working fine when I first started checking for the update (when I heard that T-Mobile was releasing it OTA, but about a week ago I started getting that message too...restarts/power cycling hasn't helped at all.
- 08-14-2011, 11:25 AM #15
- 08-15-2011, 06:49 PM #16
Sounds like the OTA is no longer being pushed out because people were having problems so now the only option is the LG updater.
- 08-19-2011, 01:26 AM #17
Used the lg update tool on my refurbished g2x. The installation completed fine but I can't make phone calls an have no data service I'm going to try getting a new sim card tomorrow hopefully that fixes the problem. I doubt it though because I have a question mark on the battery in notification bar, and in settings says I have 999% of battery. Maybe I can get a new g2x with out the backlight issue
Just got my new G2x replacement came with gingerbread and no backlight issue (08/22/2011)Last edited by Chicho1970; 08-22-2011 at 07:33 PM. Reason: Update
- 09-01-2011, 10:25 AM #18
I ended up having to order a replacement from T-Mobile due to a malfunction. Despite the old handset saying Froyo was the current version, the new handset arrived with Gingerbread installed.
So far, it's working very nicely; no reboot issues and batter life looks to be improved. So why aren't all G2x getting the update?
- 09-02-2011, 11:16 AM #19
A lot of the second and third replacement phones can't due to a paperwork snafu on T-Mobile's part. And T-Mobile pulled the OTA update. As far as I know, the only avenue available to update and get the new baseband is thru the LG Updater.
Otherwise, cwm has to be flashed with NVflash, and then you can flash any rom you want. You'll still have the original baseband tho.Lindel -- T-Mobile LG G2X
- 12-16-2011, 04:59 AM #20
I finally got my ota update to gb used it for two days. The phone locked up last night wouldn't turn off or anything so I pulled the battery out and rebooted when it booted up all my paid fo apps were gone all my settings everything. Sure hope I don't have to pay for documents to go again I only had it for
about a week - 12-16-2011, 02:36 PM #21
If you downloaded from the Market you will be fine downloading your paid apps. Open Market app and hit menu and click My Apps.
Reply
