Hi everyone, I've done a little searching around for this answer but couldn't find anything definitive. I am looking for a way to run the phone only on wifi while going to another country. I was able to do this easily on my Blackberry by unchecking the Mobile Network box under network connections and having wifi enabled. I was then able to make/receive calls, get email, browse, use apps, and text when using a wifi network (as if I was still in the US) and everything would be disabled when not in a wifi network.
Basically, I do not want the phone to roam and use up data when I'm not on wifi. What is the simplest way to achieve this on this phone? How can I confirm that I am running solely on wifi? I've only had this phone and been using Android for 6 days so not totally sure how it works.
I tried turning on airplane mode and then turning on wifi. It lets me browse and use apps but no calls and no texts.
Thanks in advance!
Thanks in advance!
