Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Like Tree2Likes
    Default Need rooting help
    I have rooted other phones in the past with no problem. For some reason my One X does not seem to want to be rooted. I have unlocked the bootloader and tried everything I can read on how to flash a rom. Every time I try to boot to recovery it locks up. I have no idea what I am doing wrong. If there is anyone willing to help me I would greatly appreciate it. I have tried going through other threads but it is all getting very confusing and I am starting to regret trying this.
  2. #2
    Bizzle69's Avatar
    Posts
    ROM
    ViperXL/Dirty Rom
    Default Re: Need rooting help
    Well, first: do you have the XL (at&t/rogers) or an international one x? And what recovery have you installed? If you have a oneXL you should only use TWRP (CWM is NOT designed for the XL and can cause problems).
    If you have the OneXL, use this toolkit and follow the instructions, super easy
    Now if you have hboot 1.14 (rooted after the 2.20 update) you will need to fastboot flash the boot.img while in your bootloader menu, then go into recovery and install the rom.zip to get the roms to flash properly (this can all be done through the toolkit)
    HTC One X AT&T
    Viper XL 3.2.4: ROOTED 2.20 : Hboot 1.14 : S-OFF!
    Nexus 7 - Dirty Rootbox v2.0
    If I helped you out, hit the thanks button on this post!
    i have att&t one x. i have unlocked bootloader and installed twrp. it just freezes when i try recovery. i dont understand the fastboot flash the boot.img part though.
  4. #4
    Bizzle69's Avatar
    Posts
    ROM
    ViperXL/Dirty Rom
    What version of TWRP? I'm running 2.3.1.0 with no problems. Just use the toolkit, flash the TWRP recovery that is included...
    Make sure you have the rom.zip of whatever rom you are flashing on your sd card and PC. Also go into developer settings and make sure USB debugging is on.
    Then the bottom left box of the toolkit has a "flash a kernel", (whatever rom you are trying to flash, make sure you extract the boot.img to the /data/kernel directory of where you installed the toolkit on your PC)
    Select "boot to bootloader" in the toolkit, then flash kernel through toolkit, as soon as it says "press any key to continue" in the cmd prompt on PC, reboot phone back to bootloader (if it reboots itself and goes past the bootloader, don't worry, you can still get back, just use the toolkit to send command or hold power button and volume DOWN button on phone til screen turns off, then let go of power, but continue to hold volume DOWN button til you see bootloader menu)
    Now go into recovery, select wipe>factory reset and system (some roms will do this durring installation, but it is always wise to do this first).
    After wiping, go to install, and select the rom.zip from where you put it on the phone. MAKE SURE IT IS THE SAME ROM.ZIP YOU FASTBOOT FLASHED, otherwise it may not boot.
    After installing the rom, reboot the phone. First boot may take a lot longer than usual, this is normal
    EDIT: if you have not put the rom.zip on your phones sd card yet, you can select "mount" in TWRP, then "mount USB" to add files from your PC (the computer should recognize your phone as long as you have the drivers installed)
    HTC One X AT&T
    Thanked by:
    VDub2174 likes this.
    this is what it says in the boot menu if this helps.
    tampered
    unlocked
    evita pvt ship s-on rl
    hboot-1.14.0002
    radio-0.19as.32.09.11_2
    opendsp-v29.1.0.45.0622
    emmc-boot
    jun 11 2012,14:36:28
    i hope i didnt screw my phone up. now it keeps going to recovery and locking. i cant even get my phone to boot at all.
  7. #7
    Bizzle69's Avatar
    Posts
    ROM
    ViperXL/Dirty Rom
    Yep, you have hboot 1.14... That means you need to fastboot flash every rom before flashing it in TWRP... There is another way to fastboot, but I'll explain that later as its not possible for you at this time (till you can boot up into a rom)
    Try to install TWRP through the toolkit, when you initially installed it, it may not have installed properly.
    HTC One X AT&T
  8. #8
    Bizzle69's Avatar
    Posts
    ROM
    ViperXL/Dirty Rom
    Quote Originally Posted by weavertim View Post
    You can't do anything in recovery?
    HTC One X AT&T
    it just seems to freeze on recovery screen. not sure how long it should stay on this screen.
    HTC quietly brilliant
    this build is for developement purposes only
    do not distribute outside of htc without htc's written permission.
    Failure to comply may lead to legal action
  10. #10
    Bizzle69's Avatar
    Posts
    ROM
    ViperXL/Dirty Rom
    Oh, that's your splash screen... Have you seen a dark blue screen that says "team win"?
    HTC One X AT&T
  11. Thread Author  Thread Author    #11
    no. it just sits on this screen. been about 5 minutes so far.
  12. #12
    Bizzle69's Avatar
    Posts
    ROM
    ViperXL/Dirty Rom
    Ok, reboot to bootloader and try and flash the recovery TWRP from the toolkit on your PC.... Sounds like recovery didn't get installed before, or didn't stick
    HTC One X AT&T
  13. Thread Author  Thread Author    #13
    ive done it and still get the same result
  14. #14
    Bizzle69's Avatar
    Posts
    ROM
    ViperXL/Dirty Rom
    Have you tried to send the command "reboot to recovery" from the toolkit?
    HTC One X AT&T
  15. Thread Author  Thread Author    #15
    says device not found. i cant even get my damn phone to boot now. might not need to worry about ti soon because im about to smash it.
  16. #16
    Bizzle69's Avatar
    Posts
    ROM
    ViperXL/Dirty Rom
    You may have corrupted your sd card (don't worry, you can format it through the PC if this is the case).. Plug it into your computer while in bootloader menu (make sure you are in fastboot in bootloader)
    - - - Updated - - -
    I know your frustration, but you can still get this to work
    HTC One X AT&T
  17. Thread Author  Thread Author    #17
    every damn thing i donow takes me back to the loading screen that we have talked about. i cant do . nothing seems to work.
    - - - Updated - - -
    i am seriously about to flip out and have a broken laptop AND phone.
  18. Thread Author  Thread Author    #18
    i cannot gert past this damn loading screen. i dont know what else to try.
  19. Thread Author  Thread Author    #19
    and my phone doesnt show up in explorer no matter what i do. so i cant even format
  20. #20
    Bizzle69's Avatar
    Posts
    ROM
    ViperXL/Dirty Rom
    Press and hold power button and volume down... The three buttons at bottom will flash 11 or 12 times, continue to hold volume down and let go of power button once the screen turns off... I had the splash screen bootloop before, and I kept trying and it eventually worked
    HTC One X AT&T
  21. Thread Author  Thread Author    #21
    i promise you ihave tried this multiple times.i really dont know what to do here. everything i do makes it go to that splash screen and it just stays there.i am completely screwed. this is the only phone i have and i cant even get it to go back to normal at this point.
  22. #22
    Bizzle69's Avatar
    Posts
    ROM
    ViperXL/Dirty Rom
    If you have no other options, I'd try to find someone on Craigslist that can do it for you.. Hell, if I lived closer I'd do it for ya.
    Google search the problem "one x splash bootloop"
    EDIT: or you could try to return it to the att store and say it randomly rebooted and you have no idea what happened, if you purchased it recently they may help you out
    HTC One X AT&T
  23. Thread Author  Thread Author    #23
    but wouldnt they say something about it being unlocked? or tampered??
  24. #24
    Bizzle69's Avatar
    Posts
    ROM
    ViperXL/Dirty Rom
    Yes, that is a possibility.. Or they would tell you to call the 800 number for a manufacturers warranty replacement
    HTC One X AT&T
  25. Thread Author  Thread Author    #25
    i believe id feel better just taking a hammer to this piece of phone.
  1. need rooting help
    By weesy in forum Sprint Galaxy S3 Rooting, ROMs, and Hacks
    Last Post: 09-23-2012, 04:59 PM
  2. Need root help in NJ
    By EMSChiefNJ in forum Verizon Galaxy S3 Rooting, ROMs, and Hacks
    Last Post: 08-07-2012, 09:37 PM
  3. I need root help!
    By 47.reed in forum Motorola Droid X2
    Last Post: 03-23-2012, 01:07 AM
  4. Android Noob Needs Rooting Help
    By iTz Nicholas72 in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 10-24-2010, 08:07 PM
  5. need root help
    By shenze in forum HTC Hero Rooting, ROMs, and Hacks
    Last Post: 07-06-2010, 06:14 AM
