Not staying connected to WiFi
dsx968
188
Since switching from the S3 to the Note 3 I have noticed when connected to WiFi in many areas I get a message saying the connection is unstable and it disconnects. Even when the signal says very strong. It's done it everywhere that I used to connect except for home.
Why is this happening and how can I make it stop?
Sent from my SAMSUNG-SM-N900A using AC Forums mobile app
dkeven
193
11
been using the at&t wifi app? gave up on it and I downloaded a wifi manager from the play store called wifi connection manager and it has worked flawless at my home and work where I transit multiple aps
Almeuit
Moderator Team Leader
Moderator
Apr 17, 2012
32,277
23
Uncheck auto network switch in wifi settings and you'll be good to go
This. You can do it by going to wifi, advanced, and unchecking the boxes.
Sent from my T-Mobile Note 3 using AC Forums.
canderson55
I keep getting the message Authentication error occured, saved, secured or wi-fi disconnected because slow. But signal states VERY Strong. What's the problem???
Almeuit
Moderator
Apr 17, 2012
32,277
23
Read this.
mspace81
86
Really, I don't think it's the note 3, but Android 4.3...my new nexus would do the same things when it was updated to 4.3, especially when using public wifi..4.3 also has some touchscreen issues like you have to touch things several times or you would hit one thing and it picked another....they fixed it with a small update....Sometimes having the latest software isn't always the greatest
Gbsa
280
Ok that makes a lot of sense
sent from my fabulous galaxy note 2
dsx968
188
I disabled the AT&T WiFi app and installed the WiFi connection app suggested. No change. I will try the boxes in the advanced settings and see if that does the trick.
