checked today and it is no longer a problem of being at the topIf you see gsiff_daemon at the top of the CPU list - definitely shut down and then boot back up. That process shouldn't be the top cpu usage unless it's spinning out of control.
It definitely is. I also noticed above both the "android sytems" that were working all the time were disguised as backup assistant. Disabled both.Is battery life any better?
I had a similar thing happening with my phone since the update. Initially thought it was that I changed the brightness setting way high when taking camera shots outside, but that didn't address the issue. Then I read your post, and sure as shootin' a restart took care of the issue for me and battery life is back to normal. Many thanks!Could this be the gsiff_daemon issue? If you go into settings -> developer options and select "show CPU processes", do you see gsiff_daemon at the top of the list?
I've had this happen 3 times in the last 6 weeks. For some people a reboot works - I've been completely shutting down and then booting back up.
The main symptom is very quick battery discharge, and Android System showing as the main use of battery.
