All Things GS6: Rooting / Flashing / Unrooting / Odin / Firmware
AlphaTango414
3,939
95
Reflash stock firmware via Odin. In your Samsung account settings, turn off Reactivation Lock. Root your device again and you will not have this problem.
uw
128
HELP!!! I bought a ATT galaxy s6 that was running XtreStoLite. I was trying to flash it back to stock using the above directions, but I'm getting a failed message.
<OSM> Enter CS for MD5..
<OSM> Check MD5.. Do not unplug the cable..
<OSM> Please wait..
<OSM> G920AUCU1AOCE_CL4351102_QB4488924_REV02_user_low_ship.tar.md5 is valid.
<OSM> Checking MD5 finished Sucessfully..
<OSM> Leave CS..
<ID:0/004> Added!!
<ID:0/004> Odin engine v(ID:3.1005)..
<ID:0/004> File analysis..
<ID:0/004> SetupConnection..
<ID:0/004> Initialzation..
<ID:0/004> Get PIT for mapping..
<ID:0/004> Firmware update start..
<ID:0/004> SingleDownload.
<ID:0/004> sboot.bin
<ID:0/004> NAND Write Start!!
<ID:0/004> cm.bin
<ID:0/004> boot.img
<ID:0/004> recovery.img
<ID:0/004> system.img
<ID:0/004> __XmitData_Write
<ID:0/004> Complete(Write) operation failed.
<OSM> All threads completed. (succeed 0 / failed 1)
And then when I try to hard reset, it goes to a green screen with this message - "An error has occurred while updating the device software. Use the Emergency recovery function in the Smart Switch PC software". And when I try to it doesn't recognize the phone.
I can get to the download mode, but I can't even turn off the phone. Please help!!
uw
128
Nevermind. After 3 hours of trying, it finally passed. It must have been a connection issue. Back to stock now!!
JoyoSahab
Sir ive got the samsung s6
Android version: 5.1.1
Phone name: samsungs SM-G920V
Baseband version: G920VVRUBOK7
Sir is there any way to root this version???​
Thierry2064
AlphaTango414, thanks!
I followed another tutorial (not precise enough) for rooting my daughter's S6, resulting in a booting loop. I was ready to try any hard and long solution but the unikernel for 5.1.1 just unbricked it without wiping anything. Cheers!
Thierry
brune67
Hi, I've been searching and searching for a thread that answers hot to fix the NAND write start, Fail problem, Finally I found it, I hope.
Anyway, I bought an S6 from a friend and went straight away to getting a rom on it, Anway, I must not have been paying attention though and probably installed a rom incompatible with my version of the S6 because it would just get stuck on the logo screen, I wasn't worried though, thought I'd just throw it into odin and reflash stock ROM (5.02) but it kept failing. I scoured the web for answers but couldnt find anything solid, now that you say you can't roll back though it makes sense. He probably updated it to 5.1.1 and thats why it wouldnt work - I hope, I'm downloading a stock marshmallow Tar for the s6 now so I hope that works. If you have any other advice to give me or anything it would be greatly appreciated. @AlphaTango414
AlphaTango414
3,939
95
Hey guys. Do you know if you can delete system.img and root.img after successful rooting. These files take up 8gigs of internal memory.
Sorry for late response but no you can not. That the operating system you are referring to. You will end up with a bricked device.
Terranceperryman
4
G920VVRS4CPL3 is my Baseband version. Its a Verizon phone.. Ive been looking for a way to root my phone for the last couple of days but hadnt had any luck..any suggestions? Thanx in advance
Ife45201
