chrome for default
zainday
From home page, click path is Applications>Menu (Edit)>Reorganize Icons (Switch). From there, you can move apps in and out of the bottom in whatever order you want, you can also do a drag and drop apps into folders, and you can even add a page. After you're done, hit the Menu button and Save, then you're set. You can also change the order of your icons in the Applications listing by hitting Menu and View type.
Thanks a lot that fixed the problem that was bugging me!
karim174
