mmajewski84
is there anyone up at the moment that can use gtalk to help me through setting up the rest of what im doing, im doing the cmd stuff from term emu and after that im a little hazy on what to do. mmajewski84 at gtalk thanks =)
once you type adb shell, type su (make sure super user is installed on your phone*should be if you used gingerbreak*) and watch your phone screen, super user should appear and click the allow-make sure the always is selected) this should give you the # prompt. From here, you can type (or paste-easier) the commands EXCLUDING the # sign * make sure not to include any extra spaces*# mount -o remount,rw -t yaffs2 /dev/block/mtdblock5 /system
# cat /sdcard/flash_image > /system/bin/flash_image
# chmod 755 /system/bin/flash_image
# mv /system/etc/install-recovery.sh /system/etc/install-recovery.sh.bak
# mount -o remount,ro -t yaffs2 /dev/block/mtdblock5 /system
# flash_image recovery /sdcard/xionia_cwma_12518.6.img
# reboot recovery
(i typed all these commands including the # signs)
what did i do wrong?
I tried installing the recovery. I didn't realize it buy I had a $ instead of #. I then found that you have to type su to get the #. Now I am trying to do it and I get a message device not found? Any suggestions?
that no such file or directory on the# mv /system/etc/install-recovery.sh /system/etc/install-recovery.sh.bak
failed on '/system/etc/install-recovery.sh' - No such file or directory
And yes I'm logged in as root and yes I've extracted the flash / image files . Any ideas here?
I cut and pasted the commands and got nothing, what should happen? I rebooted in recovery and theres no option for backup and restore. Do I type su before entering commands? Do I type exit afterwards
command, it will take a second or two to do so. (at least seem longer compared to the other commands) **flash_image recovery /sdcard/xionia_cwma_12518.6.img
