Droid Ultra waiting room
YAYTech
2,371
8
Bad music what are you talking about bro? And yes when I click keep on device to the songs it doesn't save to my stock music app.
Sent from my HTC One using AC Forums mobile app
With Google Play Music, when you pin the music to the device, it doesn't just save the music in a regular mp3 format somewhere on the phone - it saves it in a proprietary format that has to be played with the G. Play Music app. It works fine offline, but you can't just play the music with another app.
If you stream the music on a data connection, it uses your data. If you stream it on wifi, or you pin it available offline, it does not use your data.
jickracer007
3
So I have had the Bionic, Razr and now the Ultra.
I am disappointed that "multiltasking" hasn't happened and the camera has major issues.
I was going to get the Note II which still isn't out of the realm of possibilities. It's only been a few hours but I think that I made a mistake to be truthful about it, I will give it some more time
MusicChris63
