sirmaru
That resembles ATT Unified Messaging Service where all family phones use the same voice mail box, sends an email when received and can be played back on my PC or any of the family phones.
Hi. I have just unboxed my Galaxy S5 (on o2) and was hoping that this Bluetooth issue that I was previously having with my S3 would have gone, but it hasn't.
Basically, I can connect to just about anything other than my car. When I try and connect to my car, it recognises the connection, asked for the pass code, says it is connected, but then nothing happens.
This issue is related to making and receiving calls in the car through the hands free system.
I know the issue isn't the car though, as I have tried various different handsets ,and they all work. Just not my old S3 or this new S5.
Any ideas or suggestions?
My car is a BMW 325Ci E46.
It is just so frustrating as I have to remember my little Jabra Arrow everytime (sounds minor) but when you've not needed it for over 5 years, it gets frustrating.
Thanks in advance.
Gavin
Hi,
I'm having a very similar problem with Bluetooth. I have a 2012 VW Jetta and my Motorola Razr worked perfectly on Bluetooth. I just got the Galaxy S5, and I deleted the Motorola, paired the S5, and the directory downloaded. However, when I go to use voice commands to make a call, it tells me that it cannot find the number and to select it from the list (on the nav screen). I have gone through every possible combination and permutation I can think of to reset, re-pair, re-everything. I just called the Volkswagen dealer, and they said there is no upgrade available on their end. Very frustrating... I gained a great hand held device that does everything I can imagine -- except work as a hands free phone in my car. Advice?
