I didn't like beautiful widgets it wouldn't work right on my device. My location wouldn't show up. I have the fancy widget pro and love this application. I have mine set as follows and you may want to try this with your beautiful widget: you also need to make sure you are using the beautiful widget settings and the HTC weather is turned off . (I have a friend who forgot that) I don't remember the weather provider you can use on beautiful widget but with fancy I use google I have checked Use My Location but I don't have the GPS location checked.........if I have that checked it won't give me current city. I find it works best for me to have it by the current location and it works just fine. I know you have a different weather application but hope this helps you a little
