[GUIDE] Return To Stock (ODIN TARS & FASTBOOT IMGS)
Paul627g
AC Moderator All-Star
Moderator
Nov 25, 2010
15,963
2,752
Re: [GUIDE] Return To Stock
This fastboot support for Samsung Epic SPH-D700 or not???
thanks
This is the Sprint Galaxy Nexus SPH-L700 section of the forums. The section you would need according to your information is for the Sprint Samsung Galaxy S Epic 4g SPH-D700 which is located at the link below..
http://forums.androidcentral.com/sprint-epic-4g/
If you attempt to use the Odin tar's provided in the OP of this thread on your Samsung Epic 4g you will have a nice paperweight.
Fastboot and the fastboot provided files in this thread does not apply to the Samsung Epic 4g.
Good luck and enjoy!
jean15paul
Trusted Member
Jun 17, 2011
1,222
41
48
Thanks Shabbypenguin. I used these files to return my bootlooping GNex to stock last night! :)
markmorto
Coming from Kit Kat, I had to use the stock FC12 tar to get my device back to stock, since none of the others seemed to work. The only problem I'm having now is that the LTE tar seems to hang - for some reason, it just times out. The phone is up and working, but it would be nice to get 4G going.
EDIT: Never mind - it's working great once I turned it on in the settings. Doh!
Ife45201
