Question.... WHen I go to install the sdk.exe setup for windows I get this error:
Failed to fetch URL https://dl-ssl.google.com/android/re...repository.xml, reason: HTTPS SSL error. You might want to force download through HTTP in the settings.
Any Ideas??
I am running windows vista... This happens after I download the sdk and then try to run the sdk.exe
I am using this method and installing the sdk for windows:
http://www.androidcentral.com/taking-screenshots-without-root
Any Ideas??
