My problem is I can't choose custom music for my alarm or timer with the stock clock app because when I go to the Music (on storage) option it says "No music." There is music on my phone, I used to be able to choose music and I had alarms with custom ringtones but after I cleared data and cache on the app to try to fix it the alarms are gone so I'm stuck with stock ringtones now. I have a custom song set for my ringtone when I get called, but the phone app has the same problem so I won't mess with that.
I have the Honor 8X Max global version if that's important. I have tried to disable and block privileges from as much of the Huawei spyware as possible. Clock has full privileges.
