A
Android Central Question
Lately, I have been getting an error message when i attempt to charge my phone with a usb cable: "Moisture has been detected. Unplug the charger and wait until both the charger and usb port are dry." Assume as an absolute fact that there is no moisture anywhere in either place. Whatever sensor it uses is broken.
What I need is an app, or a set of steps to take to disable this notification, so that i can resume normal use of the USB port without the annoying interruption.
Please understand that i have the ability to search the internet, and the following advice is not what i am looking for and is otherwise unwelcome:
-- Drying tips. Yes, I've put it in rice. Yes, I've used duster and blown in it. Yes, I've used a cotton swab. Yes, I've put a pin in to try and dislodge debris. Yes, I've used a hair dryer. Yes, I've used a vacuum cleaner.
--Reboot it! Yes, I've booted in safe mode. Rebooted it. Plugged it and unplugged it with every possible procedure to try and trick the thing.
--Wireless charger! I want to use the USB port to charge and otherwise use the phone as normal.
--Wait around! I've waited around long enough. There's absolutely, positively, for sure no moisture. I need to continue using the phone as normal.
--Call Samsung/ATT! I don't want to pay for a new phone, I want to use this one.
--Other unsolicited warnings, care advice, or other such nonsense. I wouldn't be posting asking for this sort of brute force last resort if I had the capacity to care in the slightest for such nonsense.
What I DO WANT: an app recommendation, or a set of procedures, that will result in the disabling of this feature such that I can resume uninterrupted, normal use of the USB charging port.
Thanks for the help!
