How to fix Synapse not supported-no uci support on N910c (Small Tutorial)
stonebridgegr
4
Hey guys, today with a member on xda found a way to fix the error messages on Synapse applications. Be carefully because some tools on the Synapse doesnt works on our stock kernel. A BIG THANKS TO @yarpiin and Synapse script tool. I am not coocked the script, i just found a way and with another member we change some lines on the code. The original thread you can find it here [ZIP] Synapse + Script => Universal Kerne… | Android Development and Hacking. I am not a dev, i am here to help you. So press the button thanks
Requirements
1. Root https://www.youtube.com/watch?v=q9lNRDc_p2c"]https://www.youtube.com/watch?v=q9lNRDc_p2c
2. Busybox last version installed on /su/xbin https://play.google.com/store/apps/details?id=stericson.busybox&hl=el
3. init.d script [MOD][APK+SCRIPT+ZIP] Enable Init.d for Any … | Android Development and Hacking
4. Synapse https://play.google.com/store/apps/details?id=com.af.synapse&hl=el
5. UKM_v3.8.1 n910c Zippyshare.com - UKM_v3.8.1 n910c.zip
6. Stock kernel
7. 6.0 touchwiz(i dont know if it is working on Custom roms)
8. twrp recovery https://dl.twrp.me/trltexx/
9. flasify https://play.google.com/store/apps/details?id=com.cgollner.flashify&hl=el
10. Terminal Emulator https://play.google.com/store/apps/details?id=jackpal.androidterm&hl=el
How to install the script
1. Connect your phone to your pc or download direct the script. but you must put the script to your sd card external or internal.
2. Make sure your device is rooted and you have the latest version Supersu https://www.youtube.com/watch?v=DoIJQ1yQhwg"]https://www.youtube.com/watch?v=DoIJQ1yQhwg
3. install twrp recovery on your N910c note 4 Installing TWRP 3.0.2.0 recovery on Note 4 (… | Samsung Galaxy Note 4
4. After the succesfully root, you must download from the Google play the busybox.
5. Then install the flasify from google play and open it, then give it grant permissions, after this press on zip file and choose a file, file explorer, navigate on Sdcard and find UKM_v3.8.1 n910c
6.After this, DO NOT OPEN THE SYNAPSE. Go to terminal emulator and those following commands [HIDE] type su (give it to supersu permissions)
type uci
type uci reset
type uci[/HIDE]
7. Go and open the Synapse application, if you receive error like ' No uci support' go on settings- applications find Synapse and do a cache clean then go on the terminal and type the up commands.
again, BIG BIG thanks to yarpiin for everything and to apb_axel and his crew!!
Original post on Xda for the edited script How to fix Synapse not supported on N910c (S… | Samsung Galaxy Note 4
Original post on Xda for the Universal Kernel [ZIP] Synapse + Script => Universal Kerne… | Android Development and Hacking
