Just received this and it appears to be exactly what I was looking for: LG Car Mount 4 5 6" Cradle Holder SMARTFIT2 for WCP 300 WCP300 Qi Wireless LG | eBay
It does not come with the Qi charger (LG WCP-300), I had heard that a PowerBot puck (Amazon.com: PowerBot® PB1020 Qi Enabled Wireless Charger Inductive Charging Pad Station for All Qi Standard Compatible Devices Including Samsung, iPhone, Nokia, Google, Nexus, LG, HTC and Other Smartphones with Receivers (AC Adapter Excluded. 2 x Mi) would work and it does.
At $49.99 without the charger it is a bit cost prohibitive but since I already have several "pucks" it wasn't so bad.
It has a basic base that I could give or take, I plan to use an old Ram Mount base (see pics).
It has a great one handed operation for releasing the phone and that was important for me. Some of the other units require prying the phone out from between the prongs that are heavily spring loaded...pain in the ***. This unit has a button underneath that releases the tension of the prongs.
I like installing the phone with 2 hands because it allows me to regulate the amount of pressure I want to use to hold the phone in place. The prongs have red rubber grips that appear to hold the phone very comfortably.
The unit uses a micro USB (not included) versus the Nokia's that have a proprietary charging cord.
Even hold the phone with a case.
Various mounts from old car docks, not sure yet what will work best.
My old set up, glued a Nokia DT-900 (http://www.amazon.com/Nokia-DT-900-Wireless-Charging-Plate/dp/B00A3NCC5K/ref=sr_1_1?ie=UTF8&qid=1409078305&sr=8-1&keywords=nokia+qi+charger) to a universal mount. Screwed additional arms on the unit because the phone slipped out once.
I will post pics once I decide where and how I want to mount the unit in the vehicle.
