Multi view update on December 27th!
squeakywipers
4
Hey y'all,
I have an AT&T Galaxy Note 2, but it's been unlocked and I'm currently in Canada for the holidays using it on a Telus.........Can I expect an update? I tried updating and setting date/time to a few days from now but no luck :(
dodong27
245
Of is correctly implemented, it is designed so that you can move it around, which ever side/top or bottom fits you. You also should be able to use any application with it. But it seems like they haven't got it right and is just the first version of it.
Tsk! After all this time, you would think they could at least do that. Back to my clean...
With my Multi-Window, I can move the Task Bar around just like advertised, and Edit, so it's all good over here..!!!
MatroxD
482
You should be good then. Can you add any app to it yet? I am just debating going back to stock. But if it isn't worth it, I'm not going to?
anon(590893)
66
Does the update require the device status to be "Normal"? I had rooted then unrooted a few days back but didn't run TA, so my device is unrooted, but says "Modified"?
Edit: Just completed the update and answered my own question. It changed my device status to "Normal".
MatroxD
482
As another person stated, it allows you to kill some apps, clear cache, uninstall a few, etc.
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
ItsaRaid
613
10
It's nothing but an app that lists currently running tasks and it gives you options to stop the task from running if you want to. This is not a new feature. I've been using this since the original Note came out.
Thank you..I didnt know it even existed. I usually hold the return key and then trash all the frequently used apps
MatroxD
482
Application Monitor. ..can you explain what it is or does
He does great videos that explain things I have never seen on other series. I am up to about number 25 of all his, but they are well worth it and the time.
omcars
