Got my LG V30 for just over a week now, I thought the Volume output from very the headphone jack was low from the first time I tried out my headphones. Suddenly I noticed the Volume went almost 50% louder.(After removing headphones and plug them back) Now I thought that's more like it. I thought why has the volume suddenly got louder so stopped the music, pulled out the pull from the head phone jack, then back in, at exactly at the same volume level before removing them,(50) again the Volume was down my half again. Really strange. Just to make sure the problem was not with the headphones I tried them on my other phone and my sound card no problems there what so ever.
To make matters worse the output 95% of the time defaults to the low volume output. I may get the higher volume level may be every other day, but as soon as I remove the headphones can't seem to get the higher volume back. I'm suspecting the LG DAC is not reading my headphones properly?.
By the way I got a pair of Master & Dynamic MH30 headphones. The phone behaves the same with other headphones tested.
May I also add, the Volume does not suddenly go up or down during playback, the change in Volume only happens when completely starting a new listening section, as per plugging in headphones. The volume remains either high or low, which every is the case as far as the Headphones are not removed from the headphone jack.
Any help or suggestions welcome.
Thanks
Thanks
